SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
SOURCE: Pioneer GM-232 Amp
these are from the actual owners manuel-i used to have this amp also. hope these help
SOURCE: auto speaker wire diagram
FYI - I just took our 2004 Sequoia in because of speaker rattle coming from the front door speakers. Before I could tell them the problem, they guessed what it was. They see loads of Sequoias and Tundras with JBL systems due to the front door 8in speaker, basically, coming apart. His suggestion was to replace only the bottom 8in speaker, because the top tweeters usually are in good working condition. There is a minimal failure rate on the tweeters.
SOURCE: Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
SOURCE: 2007 toyota camry jbl wiring diagram
Do not attempt to hardwire this. Here is the part you need: http://metraonline.com/part/TYTO-01
