Have a sub zero bottom freezer. The drain in the back of the refridgerator appears to be clogged. i don;t know where this drain goes to. There is now ice formation in between the cripser drawers all the way to the front of the fridge- obviously it melts and is dripping out of the fridge. I don;t know if this matters, but i do have an ice maker in the freezer
We have cleared / de-frosted the drain twice and it keeps freezing up, causing the accumulated ice problem to recur. Should the freezer settings be changed?
We are using High Temp pressure steamers for unclogging drain lines. 10 seconds and all done :))
http://www.SubZeroLosAngeles.com
The drain needs to be cleared so that the water that is produced during the defrost cycle has a place to go, namely to the evaporation pan where it will evaporate.
thank you for the advise - i don;t know how to do this - i have tried to unclog the small tube, but have been unsuccesful. any suggestions on how to do this? i can only get to the tube from inside the fridge, right?
