20 Most Recent Sub-Zero 700 Refrigerator Freezer Drawer-700 Sub-Zero Questions & Answers
Water is leaking out from the fridge floor onto the ground.
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
11/19/2013 1:08:52 AM • Sub-Zero 700... • Answered on Nov 19, 2013
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
10/23/2013 3:55:39 AM • Sub-Zero 700... • Answered on Oct 23, 2013
In the control panel apear two bars like this - -
You have a code error that needs to be fixed. Call either your mfr or refer to manual or google the problem , include. Model # and code .
2/10/2013 1:24:55 AM • Sub-Zero 700... • Answered on Feb 10, 2013
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
12/19/2012 10:33:50 AM • Sub-Zero 700... • Answered on Dec 19, 2012
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff. take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose. Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser. Possible that the condenser FAN stopped turning. That will ice up and melt at random: see/hear that the fan is working. If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
11/26/2012 5:13:17 AM • Sub-Zero 700... • Answered on Nov 26, 2012
2answers
Sub zero side by side door won't open till about
When you open the door and then close it they will cause a vacuum. some freezers have a pressure relief. if the heater stops working on the relief it will cause this.
1/29/2015 7:15:08 AM • Sub-Zero... • Answered on Jan 29, 2015
What can I do to get the ice cream to be frozen?
It might be a good idea to clean the condeser coil. If the coil is blocked, your freezer will not get cold enough.
6/3/2014 4:34:58 AM • Sub-Zero... • Answered on Jun 03, 2014
0answers
My freezer in my sub
clean the radiator and check the freon.
11/15/2013 7:39:02 AM • Sub-Zero... • Answered on Nov 15, 2013
Convert r-12 to r134a
if the compressor is r12 and want to use it with 134a you need to change the oil in the compressor before you do the change, and while you change if make sure that he 1st 50oz of gas you charge it with the compressor off. its recommended r12 because it works better at high temperature.
11/15/2013 7:16:28 AM • Sub-Zero... • Answered on Nov 15, 2013
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
11/15/2013 6:55:53 AM • Sub-Zero... • Answered on Nov 15, 2013
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
10/23/2013 3:58:27 AM • Sub-Zero... • Answered on Oct 23, 2013
I have a Sub-Zero 501 F upright freezer. I have
sounds like the mullion heater (drain tube heater is open). take back off (after removing all shelves, including the glass tray (remove 4 screws). Pull back out, careful not to pull wires off T'stat. Run the new wires on heater behind evaperator, placing heater down in drain hole. Good LuckJoe
9/10/2013 12:46:38 AM • Sub-Zero... • Answered on Sep 10, 2013
0answers
Freezer coil inside freezer box
There are three parts to all defrost systems. 1. Defrost Heater2. Defrost Timer3. Defrost ThermostatWithout a model number I could not look up a diagram or part numbers. I very seldom see a bad heating element. Most common is a bad defrost timer, second most common is the defrost thermostat.
8/3/2011 1:01:43 AM • Sub-Zero... • Answered on Aug 03, 2011
Freezer not getting below )
The condenser is the 'radiator' located under the unit near the compressor. If it's clogged it will cause this. Make sure, also, that the fan at the condenser is operating.
If you've not yet cleaned the condenser, do so with a vacuum both sucking, and then blowing, to clean it well. BE READY FOR A DUSTY MESS!!
6/18/2011 11:12:47 PM • Sub-Zero... • Answered on Jun 18, 2011
Freezer doesn't cool but refrigerator
Check the relay on the freezer compressor. It may be shot.
themobilian_2153.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4/16/2011 12:45:29 AM • Sub-Zero... • Answered on Apr 16, 2011
Our sub zero refrigerator compressor
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2/6/2011 3:17:19 AM • Sub-Zero... • Answered on Feb 06, 2011
Freezer door "locks" or is
This is normal. Freezers have a vent port to let high moisture out. When you open the door moisture laden air enters. When the door is closed the hot air from outside expands and leaves through the vent port. This creates a vacuum in the freezer that lasts a few minutes. No problem
9/16/2010 4:48:37 PM • Sub-Zero... • Answered on Sep 16, 2010
Sub-Zero 700 Refrigerator Freezer Drawer-700 Sub-Zero Logo
9 questions posted
Top Sub-Zero Freezers Experts
Marvin
Marvin
Gil Shultz
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
View Most Popular
Sub-Zero Freezers
  • Sub-Zero Freezers
Most Popular Question
water leaking out from fridge floor onto
  • Freezers
