Akai PT4298HD Rear Projection Television Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AKAI LCD TV PLAYER COMBO WON'T TURN ON - UNPLUGGED IT AND HELD POWER BUTTON DOWN IT STILL WON'T WORK. TV about 3-4 years old.
Anonymous
Level 2:
  • Expert 147 Answers
  • Posted on Aug 08, 2009
Anonymous
Expert
Level 2:
Answers
147
Questions
0
Helped
45583
Points
463
Replace all capacitors on power board.
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
2helpful
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
20 inch LCD TV/DVD PLAYER COMBO MODEL#. CFTD2011 When pluged in tv will not turn on with remote or power button
either a power supply failure of some kind or the set is in shutdown because of a short somewhere inside---old or new unit?
1helpful
2answers
How do you put on a power supply board back on correctly
you need to look at the connectors that are from the other boards that you removed when you took the old board out. then just place your new board in and screw in the screws and plug in the connectors
2helpful
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
2helpful
My Akai LCD TV/Dvd player will not turn on
http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
RED LIGHT IS ON BUT IT WILL ON TURN ON(GREEN)
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance
2helpful
5answers
Power supply
Its possible that it is the power supply. If you wanted me to take a loot at it I could but you would need to remove the power supply from the TV and ship it to me. The power supply has been a common fail point of TV's, VCR's and other home electronics in the past several years. Let me know if this is something you would like to discuss further. I just need contact info.
2answers
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Akai LCT2701AD - 27' LCD TV/DVD Player Combo
I don't know if I solved the problem. I find though if I turn the TV off and unplug it and then plug back in when I want to watch it - it works. I don't know why but it does. My remote still does not connect to the LCD but I have cable HDTV so chanel changes work from that control.
I am pretty ********** that it is only a year old and this has happened but what can you do? We live in a disposable world.
I was trying to get to your Premium assistance Plan from where I wrote my issue but I don't know where to pay or what to do on your site it keeps taking me all over.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
