Question about Maytag Refrigerators
I changed the heater coil in Maytag Maytag MZD2766GES BUT STILL FREEZES UP ON COILS
Posted by Darry Brian Jackson on
Bernadette Clarke
    New Friend:
  • 15 Answers
Did you do it yoursel. It may b the fan. Check for pipe blockages. Call a repair man. If you have his work will b warranted
Posted on Apr 03, 2019
The freezer side of our maytag side by side just stopped staying cold, the fridge part seems cool still but maybe not quite as much as before, you can still hear the entire fridge working, we took off the...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Jul 23, 2011 | Maytag MZD2766GES Side by Side...
Maytag refrigerator moldel msd2756dew coils are freezing over
There are three magor parts that control the defrost on your model MSD2756DEW Refrigerator. The=> MSD2756DEW Controls are inside the fresh food compartment and behind the controls on the top shelf. In that photo is position 13 That is your ADC or adaptive defrost control part number=> 61005988
This is most likely the reason for not defrosting and causing the evaporator to ice over. The next part is the=> 61006199 Defrost Heater with Defrost Thermostat
sea_breeze_142.jpg Here is a PDF of a Maytag MZD2766GES and it has the same parts as yours so click here=> Maytag MZD2766GES Just use it for illistration or parts. Click here=> Defrost Heater Assembly to see that part and at bottom of page there is a short movie of how to test the defrost heater with an OHM meter. This is not hard to do if you want and I will be here if you need to ask other questions. If you have questions please let me know, Thank You, Sea Breeze
Apr 18, 2011 | Maytag MZD2766GES Side by Side...
Refrigerator does not cool. Coil in back of freezer has lots of ice and frost on it. What do you think the issue is? Thanks. SIde by SIde Maytag Model mzd2766ges.
with out question your have a defrost problem . either the heater / thermo or adative defrost control has failed . i would ck the heater . i think you will find it ok . then replace ( don't ck it just rep it defrost thermo . and if problem does not go away then the a d contorl . and its a little harder to repl than the others. .. mm majic **** .
Oct 22, 2010 | Maytag MZD2766GES Side by Side...
Maytag mzd2766geb fridge side is not cooling, freezer side is fine. we have vacummed bottom of back. compressor is hot to touch, coils are cold fan on coils is working
cjk the fans and if working . the defrost system is failing it may be a defrost terminator ( very common ) ar the a d c aditive defrost control . mm
Oct 21, 2010 | Maytag MZD2766GES Side by Side...
Maytag MSD2556AEW coils are freezing
you may want to replace the defrost thermo as it is most common / the defrost heater is probably ok / then the ADC / hope this helps .. ****
Jan 17, 2010 | Maytag MZD2766GES Side by Side...
Freezer works but refgrigerator section keeps barely cold
remove the back plate. check to see if the evaporater coils is completely iced over. If it is then your problem is the defrost system. the solution is either you timer, thermostat or element heater. very cheap to fix. if not, then check your damper. it may be that the mechanisim is not shuting or opening correctly and thus regulating air control to the right side of the refrigerator.
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
Our maytag refrigerator runs nonstop and doesn't get as cool, even after cleaning coils
Chek the interior lights. Make sure they are turning off. One bulb will cause these symptoms. Is the bondensor coil hot( it's the coil under the unit. If it is, The fridge is working but has a heat source that won't quit or run out.
Nov 17, 2009 | Maytag MZD2766GES Side by Side...
COILS IN FREEZER COVERED IN ICE
Sounds like you have a defrost timer issue. It could also be a defective defrost heater, or high temp. limit control. Most likely it is the defrost timer though. Hope this helps
Oct 11, 2009 | Maytag MZD2766GES Side by Side...
Running all the time
The temp control working ok? Thye defrost element was burned? Your refrigerator has a adaptive defrost control also part number 12002104 Are condenser coils clean? Fans running bhelow and inside? I can help you if you need, Thanks, Sea Breeze
Apr 01, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator not cooling but freezes
You might try vaccuuming under the frig to clean the coils so it could disapate the heat more. This could cause that sytem. Also if the fan is not working.
Hoped this helped. If not let us know.
Mar 16, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
48 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
