Microwave Ovens Logo
Liz Nash Posted on Mar 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch microwave diplay is dim
Model # HMC80251UC/01 This diplay on the control panel is dim-almost non existent. Part is no longer available but I have seen where the repair can be done by soldering something???
  • Anonymous Feb 28, 2021
    Go here for the answer:
    https://www.diychatroom.com/threads/bosc...
shibu tv
Level 2:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 123 Answers
  • Posted on Dec 04, 2020
shibu tv
Expert
Level 2:
Greenhorn:
Cheetah:
Answers
123
Questions
0
Helped
31126
Points
165
5 Related Answers
Anonymous
  • 120 Answers
  • Posted on Oct 17, 2008
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Anonymous
  • Posted on Nov 12, 2008
SOURCE: dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Anonymous
  • 314 Answers
  • Posted on Nov 24, 2008
SOURCE: 1998 Subaru forester repair manual, Non-existent?
Yes, all the colour codes will be the same, plus 99.9% of the rest! Frankster016
Anonymous
  • Posted on Jan 15, 2009
SOURCE: How do I remove the control panel on model JE2160
You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
Anonymous
  • Posted on Jan 01, 2010
SOURCE: The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Bosch hmc80151UC/01 (MW/Convection) not heating
MAN! I hunted and hunted for you but BOSCH is one of the poorest with support documentation! BOOOOooo... and I have a BOSCH dryer too that gets ''unhappy"...
MAYBE THIS will help you??
Of course, DISCONNECT THE POWER and DOUBLE-CHECK each fuse THERMAL FUSE and SWITCH!
That's all I can offer you my friend. METHINKS ONE of these puppies has to be bad!
Anthony
Bosch microwave oven dim display panel options to troubleshoot, model # HMC80151UC
There is a capacitor on the back board to the display. It needs replacing. They get dimmer and dimmer over the years
Sharp carousel2 microwave convection model number r-8350 flashing but control panel won't work
Many parts for this model are long since no longer available, but many generic parts are available.
Chances are your control circuit board needs repair. After all these years, the electrolytic capacitors dry internally and that can cause bizarre symptoms.
I can repair your board, normally for $54.95, which includes insured return shipping, but if your membrane keypad is bad, it cannot be repaired.
For details and more free DIY and other help & advice, feel free to contact me directly.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* (on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
I just bought the microwave/ convection oven 800 series. Do I have to take the rack out when I use the microwave, and the turntable out when I use the convection oven?
No you do not have to remove anything. The rack is made to be in there. If you still are not sure look in the owners manual or call the place where you bought it. I have a combo oven/ microwave also and can use one or the other or both at the same time
1helpful
2answers
Are you able to get a VFD separately for Maytag MMV4205BAW to repair dim display panel without doing the entire panel?
The VFD (vacuum fluorescent display) tube is not available as a separate part for this model, so you would have to order a new control circuit board.
For model MMV4205BAW, the board's Amana part number W10127098 and it runs a hefty $232.30.
BUT -
if you order the board by the original Samsung part number, you can probably get it a for a lot less.
Here is a photo of a similar board which is marked to show you where to find the full part number.
You can find links to helpful exploded view diagrams and part ordering help here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is out, you disconnect the keypad, then take out your old board and put in the new one.
Some connectors may have a lock.
The display is dim on the oven. Everything works
1. Sometimes you can clean it inside to brighten it up for a while.
2. In some cases, we can replace the VFD to brighten one up if it's available for a given model.
3. The last solution is to replace the control circuit board.
For more specifics on the options 2 & 3, we would need your brand and full model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your symptoms, "dim display".
As for suggestion # 1, cleaning:
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
3helpful
How to replace both door hooks on BOSCH MICROWAVE/GRILL
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Display not workign
Sadly, the display tube is not available separately, so the only way to fix this is to replace the board, at a whopping $181.48!
One trick that helps is to remove the control panel assembly, take the circuit board out of the frame and very carefully wipe the front of the glass and the rear surface of the control panel frame's display window.
Use a soft cloth with alcohol-based (non-ammonia) window cleaner.
That will brighten it up quite a bit.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Be sure to unplug the oven before you do any disassembly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Top Bosch Microwave Ovens Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
