Check the outdoor coil. An air conditioner works by removing heat from inside the house, compresses it, and puts it outside the house. If the outdoor coil is dirty, it can't expel heat and your head pressure will rise until if finally turns the compressor off on high pressure. Turn power off to the outdoor unit and hose out the coil really well. Let me know if this fixes your problem.
SOURCE: Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
SOURCE: Kenmore room a/c not model 70088
you can test it by running it first at 9 and observe the compressor if it is continously running and cools the room. if it does, then 9 is the coldest and 1 is the hottest setting. but if the compressor would just run a little bit and stop at thermostat setting of 9, then its the reverse. i hope i was able to help.
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
SOURCE: Elekta Window Air Conditioner, Thermostat won't cut off.
Good morning, I'm using Elekta window A/C 1.5 ton and I'm using this for almost three years and now there is eritating sound while the A/C is running. Could you please advise what is the problem?
BR/Art
SOURCE: Fridge unit was cooling poorly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
