We recently moved our rv under a covered area...Our a/c also needed coils cleaned which I tried but still the water that drains off becomes slime. I was told it is because their is no direct light on it now...Help
Use a shop vac( wet/dry vaccum) and as you clean the coils use the vaccum to remove the slime and debris. This slime is caused by particles in the air that has been drawn into the coil during a/c usage. To prevent this slime from continuing to build up you can use a tablespoon of bleach and pour it into the drainage pan this will kill all the algae producing bacteria and will keep your a/c condensate drain in tip top shape. Hope this helps Good Luck
Dave
Customer Support Center
P.O. Box 490
Elkhart, IN 46515
Phone: 1-800-544-4881
[email protected]
Sales and Marketing
2320 Industrial Parkway
Elkhart, IN 46516
Phone: 574-294-2511
Fax: 574-293-9686
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
