I see this all the time. The red or blue bag holder has either started to bow or it's legs aren't seated on the top of the little depressions. Check that and when you fit new bag remove the hose and check the little door on the bag is open and not closed if it's closed all the rubbish will fill the bag container rather than the bag. If this if the case buy new bag holder common problem.
SOURCE: Miele Cat & Dog Vacuum
I have a Miele White Star. The Turbo Plus attachment has stopped working. Brush will not turn. I've had it all apart and cleaned it. Still a no go. Is there an electrical connection somewhere. Fixable or should I just replace it? Thanks Mary
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
SOURCE: Miele Cat & Dog vacuum gets VERY hot and is
Hi
The fact that it gets very hot could be due to a number of issues.,but the fact that it started making a very loud noise at the same time suggests that there might be more problems maybe brushes etc.
If you could describe the sound it makes like a squeeling or electrical buzzing I know this might be difficult ,but it would help in the diagnosis.
I will try to get more information on the unit ,meanwhile here is the user manual pdf if you don't have it: http://www.miele.co.uk/Resources/OperatingInstructions/S%205001%20series%20S%205211_5781.pdf
