Hi Royce, for the oven temperature issue try to find the owners manual,it will give you information on how to offset the temperature setting so what you set is what you get. Now for the broiler, if it's an electronic ignition (goes click,click,click) the flame sensor might be bad or damaged. In either case call the store you bought it from or the factory authorized service provider. If it's only a month old it will be under warranty. Hope that helps.
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
SOURCE: Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
SOURCE: Why does the surface burners and broiler light but
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
SOURCE: MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dfasfdas
