Most are, (volts, amps.watts and pin wiring)
there is no standard on wall warts. ever, for sure world wide.
no thing told Prokeys 88 what is that?
ahh my wild guess is gee you posted to computers and is not
it is a music keyboard (cheap)
Prokeys 88 SONO? what is it exactly the SONO uses standarded USB power pack like used on cell phones.
the sono runs 2 ways with USB power pack
or connected to any PC with USB cable (5vdc is USB)
the non sono 88
uses a 12vdc power pack
I say use 12vdc pack 2 amps. web cameras CCTV IP cams sold vast these.
the non sono page 4 clearly states (gee first google hit too)
12vdc, 500mA (1/2 aMP OR MORE) AND CENTER PIN PLUS.
https://www.manualslib.com/manual/293107/M-Audio-Prokeys-88.html?page=4&term=12v&selected=2
EASY peasy japaneezy./
SOURCE: Quantaray tripod video camera adaptor
http://www.tripodquickrelease.com/Quantaray_Titan_II_Quick_Releases.htm
Use above link to order part QS-04
SOURCE: Power Adaptor for 500GB LaCie P3 HD USB 2.0 7200RPM 8MB USA?
Both power adaptors are 4 pin, ITHINK that the Porsche that you have is the same as mine which has the smaller (4 pin DIN) plug
34W power supply.
But check on LaCie's site:
http://www.lacie.com/asia/products/product.htm?pid=10857
Hope this helps.
Chris
SOURCE: AC/DC ADAPTOR
click on hyperlink:
buy replacement ac power charger adapter DURBRAND MODEL # APX001A
SOURCE: Prokeys 88 flashes 888 and none of the keys work.
Reset the 88 by switching off --> hold the - and + buttons while turning on. Your device will reset and usually everything should be solved.
