LG 42LD450 42 in TV Logo
Justin Woodrow Posted on Jan 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LG 42ld450 -ua the power light comes on but the screen is still off an the screen is black what can i do to fix it
  • b1jqxk44
    b1jqxk44 Jan 22, 2019
    Hi Justin Woodrow, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Like do you have sound? Is your stand by light flashing when the TV off. Is the TV clicking sound?
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on Jan 22, 2019
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86427
Points
1069
Turn it on. Power light just indicates that the tv set is receiving power. try to manually power on the tv from the button provided on the tv bottom or sides
5 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Nov 14, 2015
SOURCE: Have LG 42LD450-UA lcd tv that has no picture or sound. When plugged in the red power light comes on but when it's turned on the red light flashes very slowly continuously. Thanks in advance
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
richie46
  • 12962 Answers
  • Posted on Jun 23, 2016
SOURCE: I was watching my plasma TV LG-60PA6500-UA when I heard a loud pop sound and kept power cycling. I replaced the Y board. It turns on now but the screen is pitch black and nothing comes on the screen.
Y board affects individual display lines, x board affects all of them.
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Sep 17, 2016
SOURCE: I need a schematic diagram for an LG 42 TV Service Code 42LD450-UA.CUSWLO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
gopakumarg43
  • 76851 Answers
  • Posted on Apr 19, 2017
SOURCE: I have a LG 42LV5500-UA LED tv with a black screen. Power light comes on but that is it. Any ideas on what board needs to be replaced? right in the middle of a program went black.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
javad_tavani
Mohammad javad Tavani
  • 31 Answers
  • Posted on Oct 28, 2017
SOURCE: lg tv blink codes
Take the screen off connect power and watch LEDs if any don't flash its LEDs only needed to change faulty strip if they all flash its probably t con boards.
Fixing an LG TV model 32LG70-UA. TV has banding lines present on screen. All the capacitors look okay on the main power board. Should I just replace the entire board?
if you mean lines on the screen, white or black then the problem is the screen connection, this is not a job for the faint as it involves removing the screen casing and the screen is very delicate. on the screen connection there are strip thats connect the screen to the screen boards there is 2 boards in the screen they can come away. sometimes and they would need the padding changed and reseted, so the screen contacts properly.
1helpful
I have a LG TV Model number 47LN5400-UA. I turn on the TV and there is audio but the screen is black. If you look closely you can barely see the image. What part do I need to fix it?
It is your back light or the power to the back light that needs to be changed as to how much and how easy it is to change will depend on if you do it yourself or have a TV repair person do it.
My 42 in lg tv model number 42ld450-ua went off
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
1helpful
Screen lights up and then goes black
sounds like a coil break down under heat. It is a common fault. You will need to get it fixed at your local dealer or a repair shop.
1helpful
2answers
Lg mod 26lg30-ua picture is too dark and brightness adjustmen does not help
I suspect that you have a backlight issue. The backlight is not getting sufficient voltage usually due to a malfunction of the 12V line on the power supply board of the tv or a faulty backlight inverter board. This issue cannot be narrowed down any further without testing it. So if you are handy at fixing electronics stuff and know how to use a multimeter then let me know and I will guide you.
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
