For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Press and hold the Start pad for 5 seconds until "Control Lock" appears on the display. Repeat to unlock, and "Control Lock" will disappear from the display.
When not in a setting mode, pressing and holding UP & DOWN keys for 3 seconds, the key pad is locked. After setting it, the LOCK icon will be displayed on LCD to indicate that key pad has been locked and all the keys are disabled. At that case, the remote won't send out any codes. The LOCK icon on the LCD flash 3 times, 0.5 seconds for ON, 0.5 seconds for OFF, and press & hold UP & DOWN keys for 3 seconds, the remote is un-locked.
When the shooting information display is shown, press the [i] button (the bottom one on the left) to switch to the quick settings display. Use the cursor pad to select the shooting mode (fifth item from the top along the right edge) and press OK. Use the cursor pad to select one of the two release modes. The quick response remote mode (marked with an icon of the remote control) fires the shutter when you press the button on the remote. The delayed remote mode (marked with the remote icon and "2s" gives you two seconds to hide the remote behind your back before firing the shutter.
Full details are "Releasing the Shutter" section of the manual (starting on page 54 in my copy).
This would indicate a child lock protection is switched on which would stop you from using the manual control buttons. Usually this can be switched off from the remote control via a lock button or go into the set up menu & look for a child lock setting & then toggle it to OFF.
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B as well as locking each of the EXT inputs, so you should confirm what is locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position Or . Depending on which remote is being used Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT buttons check each channel and input to establish which channels and inputs are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option). The screen will change to show the channel lock System Menu. This screen will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5 OR: IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show the selected antenna and channel or input. The display is superimposed over the picture. This display will indicate that the channel or input is either locked or unlocked. In the lower middle will be instructions to use the 10-key pad or SCAN buttons to select the desired channels (or the INPUT button to change antennas or select the EXT inputs). At the bottom of the screen will be instructions on how to change the current LOCK status (if unlocked use the ENTER button to lock, or if locked use the CANCEL button to unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111) and then press the ENTER button.
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are locked, or, use the INPUT button to select the external inputs that are locked.
7. At each locked channel or input press the CANCEL button. The screen will indicate that the channel or input is either locked or unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
