I checked the battery in remote and there full charge and new with tv can't open that dawn tv. look for button on bottom or back to reset
SOURCE: cant switch it on!
Sounds very much like a main power supply that needs a 'kick' to start up. This is often caused by the loss of value of a capacitor in the power supply, one that handles feedback to start the supply initially and carries the signal to shut it down in case of a circuit fault in one of the areas the supply services. Inadequate feedback will make the supply unable to start properly and more likely to shut down even though no fault condition exists. If I'm right, it will get worse and searching for the problem requires an instrument not found in the average home; a capacitance meter with loss measuring capabilities.
SOURCE: the battery wont fully charge and its brand new
You have to use the charger that came with the device. If you use any other charger it will burn the device out. I tried charging mine with a 12 volt adapter in the car and this burned the device out. Not knowing I damaged it I used the 110 volt charger and found it would not charge any more. The charging current is regulated in the charger not the device. So beware.
SOURCE: I have a Kymco People
have you checked the spark plug? take it out and lay it on the engine touching a metal part and kick the bike you should see it sparking if not then replace the spark plug
if thats not the problem then give the carb a clean and check the air filter that its not blocked
2 stroke bikes need three things to work air spark and fuel as long as you have these it will work
hope this helps
John
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi:
Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link:
http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
SOURCE: my samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
