SOURCE: 2007 jeep commander rocky mountain no sound from radio
take it to the dealer. they will put a new radio in it if you have under 36000 miles
SOURCE: How to remove 2007 jeep commander climate control
The lights in the climate control panel are not bulbs, they are LED and the entire panel will need to be replaced. I would check for a bad connection before replacing the panel assembly.
SOURCE: @aolStarting today my 2007 jeep
Hi, just unscrew the end with the bulb, as it does come off, even though you adjust the beam at that end. Then you just pull the bulb straight out and replace it. Check the end where the batteries go, as if it is new, they will have a new bulb in the end cap wrapped in foam. Please rate me on my help to you. Thank you,
Shastalaker7
