SOURCE: Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
SOURCE: technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
SOURCE: How to hook up old Aiwa surround sound unit to tv.
i have this problem all the time. you have to take the back of the stereo off, then clean the lens on the CD with a soft cloth. i've tried cd cleaners that have a brush on an actual CD - doesn't work. you can only fix this problem by opening it & cleaning it with a cloth.
SOURCE: no surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
SOURCE: how to hook up wii to surround sound
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Alex
www.CAS411.com
