THE QUESTION WAS
My washing machine is leaking from top in to drum when washer is not being used. THIS IS HOW I READ IT. IF IT'S A FRONT LOADER W/M
THE QUESTION TO ME INDICATES THE WASHING MACHINE IS FILLING WITH WATER WHEN NOT IN USE / THE INNER DRUM WILL FILL WITH WATER BY IT'S SELF
3 THINGS CAN CAUSE THIS PROBLEM
1. COLD INLET SOLENOID FAULTY / OR MUCK IN IT STOPPING IT CLOSING CORRECTLY, CAUSING MACHINE TO FILL WHEN NOT IN USE.
2. HOT WATER SOLENOID SAME AS ABOVE
HOW TO CHECK . TURN OFF BOTH STOP VALVES WATER ON WATER INLET PIPES . IF WATER STOPS FILLING DRUM
THEN TURN ON ONE STOP VALVE AT A TIME TO FIND OUT WHICH ONE OF THE SOLENOIDS IS FAULTY HOT OR COLD
REMOVE FAULTY SOLENOID VALVE REPLACE OR STRIP DOWN AND CLEAN OUT MUCK,
3.IF THE DRAIN HOSE HAS NOT BEEN FITTED CORRECTLY
WATER CAN CHIFFON BACK INTO MACHINE THROUGH THE HOSE /FILLING THE MACHINE WITH DIRTY WATER
THE DRAIN HOSE AT ONE POINT OF IT'S LENGTH SHOULD BE HIGHER THAN THE TOP OF THE WASHING TUB TO STOP WATER CHIFFONING BACK INTO MACHINE. GOOD LUCK
Yes u need a water valve.
Water valve on washer bad
SOURCE: LG WFT1391TP Top Load Washer - Black Clay Pieces in Drum
Caustic soda. Be careful to wear gloves. Fill tub with water, cold will do, put in about 100gms of soda and turn on a extra large wash cycle only. Don't let the water drain, allow to stand over night, then complete wash cycle. You will find that hugh amounths of lint come loose. Repeat if necessary. I now do this about once every two months. Another thing to remember is to always leave lid open when machine is not in use, this prevents musty smells.
I have become obbsessive in sorting out the problems discussed and am now looking for a service manual for a WF-T7014PP as i want to remove the pulsators to ensure ther is no lint stuck in there. If anyone can assist please mail to [email protected]
SOURCE: LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
Here is the answer !!! My LG front loader has leaked once a year for the past 4 years. The rubber bellows (a part underneath the washer) cracks and causes the leak. DO NOT LET THEM TELL YOU THAT YOU ARE USING TOO MUCH DETERGENT ... THAT JUST AN EXCUSE !!! The part costs around $12. Here's the link ...
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx?R=1514&searchText=LG%20Washer
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
SOURCE: Maytag Atlantis Top Load MAV6250AWW Drum Leak?
During fill only
All the time
During fill only
All the time
