Check your input labels on actual crossover itself, as manual appears to have an error re inputs.
Outputs are correct, as per manual.
[+]Woofer[-]Woofer[+]Tweeter[-]Tweeter.
Positive[+] is the right hand tag of both drivers, with tags facing u.
SOURCE: Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
SOURCE: Wiring diagrams for installing tweeters and crossovers in a door
try 12voltresource.com or google "wiring diagrams for car audio"
SOURCE: tweeter plays and very low volume when in back by
This sounds like I would be trying a new crossover network module.
Jerry G.
SOURCE: what are the specs,rms ect on my older mb quart psc 216 speakers
Any type of 4 channel amp that will allow the speakers to be hooked up at 4ohm. I would check your local walmart. The brand VR3 are made by Rockford fosgate as well as lighting audio. From what I have heard they are some really good amps at affordable prices. If you are looking to spend some money I would recommend a JL Audio e2150
