I have a drain hose screwed on that goes out a window per the instructions but there is water leaking from under the AC unit. Yes, I took the plug out before I screwed on the house which "should" have made the unit drain into the hose not the tray. How do I make the water go to the drain hose and not on my floors??? Nothing in the manual about how to fix water leaking. Thanks for your help.
SOURCE: water leaking under the unit dripping on the floor
Sometimes you will get a dripping if the unit is not level, or a seal on the drain hose might be loose. but i would check to make sure the unit is leveled properly.
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
SOURCE: drain hose in floor drain but fills up water bucket
wow, that's a weird one there. just to check, you did turn thr drain connection all the way down and remove the cap? nothing inside the drain connector? the hose is not too small or run too far? is the water coming out of the hose and in to the bucket at the same time if it is I would think ther is an internal leak somewhere and take it back for an exchange if new. good luck let me know if this wasn't any help for ya
seth
SOURCE: Ewave refrigerator model EWR121W is leaking water
On the back, bottom remove the white cover. The drain hose is on the rite, you will see it.
Thanks for the advice. I raised the air conditioner up off the floor onto a table so the drain hose on the unit was higher than the window where the house went outside. That seemed to fix the issue. Previously the water would have needed to drain up and out of the house rather than a downward flow.
