I pressed the volume button on my CD player to hard now the removable face doesn't click back in is the volume button the reason?
SOURCE: Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
SOURCE: koss car radio,cd,mp3
I'm not familiar with that particular brand/model, but a lot of the models with the flip down face will actually have the eject button behind the face. So when you flip down the face, you can then hit eject.
SOURCE: Pioneer AVIC-N2 does have unlock code?
no, this radio has no security code... Check to see that you have power on the yelow wire at all times, Power on the red wire when the key is on, and make sure the black wire is grounded well. something could have been disconnected at the paint shop.
SOURCE: CD Player in Acura TL 3.2 2003
It's not that hard to fix it yourself.
for your 2003 TL
1. first remove the CD player (this is the hard part).
2. with the CD player removed, unscrew the top cover (4 or 5 screws) on the CD player.
3. with the top cover removed you can see the stuck CD.
4. all you have to do now is just push the CD out and reinstall
should be the same for your 04 TL but im not sure
SOURCE: my 2002 ml 320 press cd button it says no cd player installed
my 2001 ml 320 when i press cd button it says no cd player installed
massage. There is 6 cd changer in the back of the car ., Any suggestion for fix the cd player?
Please help.
