20 Most Recent Dual Electronics XDM6350 Car CD/ MP3 Player Questions & Answers
the USB port does not play music it only charges. the AUX is were you plug it in to get the music. If thats not it then it could be your cord. I had the same problem awhile back.
Dual Electronics... • Answered on Oct 09, 2018
ANSWER:
The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer.
Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION:
You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck!
- Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Dual Electronics... • Answered on Oct 07, 2013
the radio or car has no power?
Dual Electronics... • Answered on Feb 16, 2012
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Dual Electronics... • Answered on Jul 28, 2011
Here is the User Guide for the XDM6350:
Go to the "Installation" section and there is a wiring diagram there.
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
ANSWER: The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION: You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck! - Chris Proia
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
grab a sledgehammer, wind up and crush your dash in, after remove all parts, then put in new radio
Dual Electronics... • Answered on Jul 10, 2011
have you check the fuses in the radio also the fuses of the car and the wires
Dual Electronics... • Answered on May 31, 2011
Where is the switch so i can dim down the blue light from my stereo? and, how do i turn on the stereo beep?
Dual Electronics... • Answered on Mar 19, 2011
Dual Electronics XDM6350 Car CD/ MP3 Player Logo
31 questions posted
Top Dual Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Car Audio & Video
Most Popular Question
dual xdm6350 read or charge itouch
  • Car Audio & Video
