SOURCE: menu scrolling and can't stop it
Your set is in DEMO mode......consult owners manual....
Usually in menu pages.........Oh, switch back to English...
select Lingua to change.........T.
SOURCE: my buttons wont work on my blackberry curve
Does the phone still have a vailed warranty? If so inform the developers and they will send you another. I the warranty has expired unscrew the back and gain access into the keypad, check the circut board for and miss soldurings and if you can't find any put it back together and take it to a repair shop
SOURCE: my buttons wont work on my blackberry curve i can
I didn't drop this phone near water but felt the moisture was the issue with hot summer temps. with the 8330 bb, none of the buttons (only trackball worked- no buttons) Leaving it in rice for a day didn't work at all.
On the last resort attempt, believe it or not, the oven trick did!
1. preheated for 200˚F
2. turned off oven
3. took battery out of BB
4. placed on plate
5. left bb for exactly 20mins in closed oven
6. once i took bb out I waited 5 mins and then placed battery and turned on.
7. worked like a charm
SOURCE: I have a clarion nx501.
Please read my post here: http://community.crutchfield.com/forums/p/22187/251957.aspx (pasted below).
I hope you bought your unit at a Clarion dealer....
Hi, (Team Crutchfield - please add this to your knowledg-base.)
I'm on my third NX501 (could have been the fourth if not for working directly with Clarion).
The SD Card corruption causes both loss of Navigation and intermittent Sirius start up (it'll never acquire signal).
Your unit needs to use the exact micro sd card it came with forever (it has a permanent serial number).
You have two choices:
1. Get Crutchfield to replace the unit
2. Call Clarion (I suggest this rather than ripping your dash apart over and over).
Here's what to do. Contact:
Ben Kwan
Customer Service Technical Representative
Clarion Corporation of America
800-347-8667 ext 4342
Direct Line: 310-217-4342
Fax: 310-217-4243
Ben will have
you send your microsd and rebuild it for you and return it (likely with
the firmware upgrade that addresses this issues on another microsd that
can also be found here:
http://clarion.com/ca/en/support/navigation_updates/NX501Fupdate/index.html).
While you're at it, update the Bluetooth firmware too: http://www.clarion.com/us/en/support/software/NX501/index.html
Once you get
the card returned (THIS IS HUGELY IMPORTANT - EVERYONE WITH A Clarion
NX501 SHOULD DO THIS!!!), back it up using Naviextras toolbox (the
program clarion uses for map updates). You can get it here:
https://clarion.naviextras.com/shop/portal/downloads
Once you
follow these steps, barring your micosd physically or logically self
destructing, you'll have an NX501 that's nearly problem free and backed
up just in case that unfortunate corruption reoccurs.
Of Note: Ensure you insert the microsd card with the contacts facing up and do not force anything.
I'm extremely
confident this will make a world of difference for you (and anyone
suffering the microsd corruption of the Clarion NX501).
Regards,
Marc (mshmovie)
SOURCE: sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
