Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
Disconnect the 'DC IN' cable from the camera.
Hold down the 'Initial Set' button.
Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Are there menu settings for picture quality ? Have you got exposure compensation set too high ? Is your white balance appropriate to the subject matter and lighting ?
By the clock at bottom right there is a speaker icon that can increase volume. right click on it and click sounds, click playback tab at top, Right click on speakers and select properties, should be an enhancment tab for bass boost and loudness.
There is different sound setting for voice call and media playback.
If you press volume up key on home screen, it increase the phone call volume but not he music player volume.
You can try to increase sound of media playback. First, open music player or video player and increase the volume through volume up key. You will see media volume written on the Volume increase pop up notification.
If you still have problem, reply.
Do you mean in your camera or on your computer. If on your computer Google K-Lite. Hear you can download the codec drivers to update your computer to view and hear the movies you record.
Touch the screen to pause playback and display the movie control panel. 2. Drag up across the screen to increase the volume. Touching the volume indicator displays the volume panel.
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
