Question about Panasonic Cameras
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
Posted on Sep 11, 2016
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Posted on Jan 03, 2008
SOURCE: I would like to know
Press the Menu/Set button and from the Setup menu, select Reset.
Posted on Feb 04, 2009
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Posted on Feb 09, 2009
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Posted on Aug 23, 2009
SOURCE: how do I reset my Panasonic DMC-FX35 to facoty
you'r menu should have a reset setting, there are 2 menu's 1 when you'r ready to take a picture & 1 when you'r viewing you taken pictures
Posted on Jan 14, 2010
