SOURCE: Senville Mini Split Error Code
The E4 light on your system is saying there is a commiuntion problem between the inside unit and the outside heatpump unit.Make sure there are no loose wires and you wired it properly,The S wire is the commiuntion link wire make sure it is a solid run between both units.I had the same problem with my system and it was the s wire not making a good connection.
SOURCE: The fan on my senville aura 12000 doesn't blow high on heat what Is causing it to not blow on high
Your control switch is most likely the cause here. The one right on the dash that you are turning to adjust the fan.
