I'm using Royal alpha 601 sc .I need the name of the shop to be in the receipt
Hello, Busisiwe -
It seems you need the instruction manual for the Royal Alpha 601sc cash register.
You can find and download one (PDF version - free) here:
https://www.manualslib.com/manual/315391/Royal-601sc.html#manual
Note: You will need Adobe Acrobat Reader software (free).
Be sure to read through the full document first. Then, follow the instructions for setting up the cash register, starting on page 22 (Image 28 in the PDF version.) The instructions for having your business name print at the top of the receipt are "Programming a Header Message" (Page 28 / Image 34.) Your shop name will be "the header message."
Best wishes.
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
SOURCE: could someone please tell me where can i buy
OfficeMax and Office Depot may have them.
Storemont (online) has the Royal Alpha 601 ($6.49): http://www.stormont.basics.com/product.asp?dp=2098041&f=
SOURCE: Thermal Printer for Royal 600/601 sc Cash not printing
do you have tape in backwards? one side will print other side will not.
