Washing Machines Logo
C
COREY Posted on Apr 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A WHIRLPOOL CABRIO WASHER MOD WTW5800BW0 AND I KEEPING GETTING AN ERROR CODE OF LE WHAT DOES THIS MEAN I CANT FIND ANY INFO ANYWHERE ABOUT THIS CODE.
THE WASHER REPEATS THE WASHING CYCLE UNLESS YOU LIFT THE LID OR PRESS THE STOP BUTTON BUT YOU HAVE TO DO THIS AFTER EACH WASH.
Dw Wooten
Level 2:
Sergeant:
  • Whirlpool Expert 227 Answers
  • Posted on Apr 07, 2018
Dw Wooten
Whirlpool Expert
Level 2:
Sergeant:
Answers
227
Questions
Helped
115755
Points
551
Le mean your washer is over load light your load.
5 Related Answers
s_4u_11
sandip panchal
  • 535 Answers
  • Posted on Sep 16, 2008
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
Anonymous
  • 294 Answers
  • Posted on Apr 06, 2009
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Anonymous
  • 5911 Answers
  • Posted on Jun 11, 2009
SOURCE: Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Oct 02, 2009
SOURCE: F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Anonymous
  • 15935 Answers
  • Posted on Sep 28, 2010
SOURCE: whirlpool cabrio washer keeps flashing code F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
F#code keeps flashing on washer did what manual says to do but nothing changes can you help
The "F1" error code on a Whirlpool Cabrio washer means that the machine control assembly has failed and you must replace it. Order a new assembly from a Whirlpool parts dealer. The "F2" troubles code means that a key on the user interface or keypad is stuck. Look at each key and try to unstick it. Always hit the "Pause/Cancel" button to try and erase the error code. Try restarting the load.
2answers
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
1helpful
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
1helpful
I HAVE A WHIRLPOOL TOP LOAD CABRIO WASHER MOD. #WTW6400SW1 I AM GETTING A F1 CODE SOME TIME AT WASH CYCLE SOMETIME ON RINSE CYCLE WHAT ISTHE PROPLEM
Hello
Error code F1 is caused when the control on your washer is either bad or about to go bad. This is a common issue with Whirlpool Cabrio washers and they are aware of this. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge you for the part. Please get back to me if you have any other questions.
Kevin
8helpful
Whirlpool washer model WTW6200SW1 getting an F1 alert code can not clear by hitting cancel. keeps repeating.
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
8helpful
F54 error code
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
