SOURCE: I have a Coby Internet
these might be the initial stages of the re-flashing process ie:installing the OS or upgrading when you might connect a usb cable,im not familiar with your brand.
Walmart Product Care Plan
877-968-6391
Talk to a Human
SOURCE: rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
SOURCE: How can i reset a nabi tablet with a different account
resetting system wont clear your account password or account need to open account and click the change or edit password / account info
How do I switch from Kidz Mode to Mommy Mode, and vice versa?
To switch to Mommy Mode, simply tap the Menu Key, select Mommy Mode, and enter the password to exit Kidz Mode. To switch back to Kidz Mode, simply tap the Applications View, and then tap the Kidz Mode Icon.
also for customer support phone number is: 1-855-ASK-NABI
