Question about Tablets & eReaders
Rca tablet how do i get out of fastboot mode - Tablets & eReaders
Posted by Lynn Meyer-Parker on
  • vicente arellano
    vicente arellano Jul 14, 2020
    it starts updating but when it is finished the android figure comes out with the error message
Marshall Ross
    New Friend:
  • 20 Answers
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Posted on Nov 13, 2016
  • Doug Vasquez Oct 16, 2019
    tried to download 2x and tells me the file is corrupted what now
My daughters babrie nabi tablet is stuck In fastboot mode and it wont do anything ?
H. Done a search on babrie tablet no resault ?? Do u mean Barbie ..cheers
Mar 26, 2018 | Tablets & eReaders
Stuck in fastboot mode and cannot shut off tablet
Perhaps you may offer additional information regarding the device or product. Rephrase the question please
Jan 12, 2018 | Tablets & eReaders
Why is my tablet Stuck on entering DnX mode.Waiting for fast boot command...
my next book tablet is stuck in dnx fastboot mode, it will not unlocked, and it stuck on voice command
May 12, 2016 | Nextbook Premium 8 Se Android
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
May 11, 2016 | Tablets & eReaders
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
Jan 17, 2016 | Tablets & eReaders
I'm stuck on the fastboot mode. how to turn this off?
Its under system / developer options settings just untick the fastboot option.
May 12, 2014 | ASUS MeMO Pad HD 7
Fastboot mode
either connect this to a pc/ remove the battery, begin again.
Sep 17, 2012 | Android Coby Kyros Mid7014-4g 7" Tablet
I have a Coby Internet Tablet MID7105. In the bottom left corner of the screen, it states: "The Deviceee Enter Fastboot Mode Please Connect USB TO PC or Reset Device Waiting..........."
these might be the initial stages of the re-flashing process ie:installing the OS or upgrading when you might connect a usb cable,im not familiar with your brand.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
5,281 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
