Keep blowing heat out up 78 degrees..never did this before...I have 15 gal. Of kerosene in my tank.
SOURCE: Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
SOURCE: I set temp to 74 and stop at 70 and decresing.
The only thing I can think of other than being just old and worn out is that by design it may not be set to run but so much at a time. Has this always done this since you have had it? It may be needing calibration. One thing you can try is to set it at 2 degrees higher than you want it and then it would shut off at the temp you actually want.
SOURCE: Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
