HP computer Windows 10 Home 500gb hd on board, 2gb RAM, 3 USB ports, HDMI, Ethernet, wireless b/g/n, card reader.
These are the worst answers I have ever seen
NO PC stated at all,
Just HP, 1000s exist. w10 can run on PCs even 2005 made. even some newest Pentium 4s/D/HT .
The why to clone is easy use better software.
I can tell the PC is old, dinky HDD and worse ram.
must be w10 -32 bit I my guess,
No target HDD stated, a SSD is best for the target drive, is it?
from C to target drive,
NTI is not best ever. it is underdog class.
why not use top software for this,
pitfalls: all
cloning and and infected PC.
cloning a HDD that fails smart tests I bet your does as it is super old.
cloning UEFI enables PC (non stated)
cloning any PC with HDD encryption enable (reverse that first)
here is how to do it.
I've done this for 25 years, vast times, in fact.
http://www.pcdied.com/cloning.html
software can not make any HDD bigger.
a partition maybe but the platters can not be make larger or deeper. ever.
like making your car into a truck, same thing.
the software must change the ID of the drive as the last step or w10 will not clone.
only real cloning software certified for w10 will work. some of the best are free.
or last 30 day trail.
avoid NTI.
SOURCE: Creepy 'USB' issues...
check you USB wire end, if that center piece ( that white piece inside the connection) is missing that the problem. that white piece separates electrical connection, it it not there it causes a shorts curcuit and the pc shuts down
During setting up computer with drivers etc. System file could have become faulty some files not registered in System
You could have System file errors these files are the heart of O/S
whereas the reg is the blood if System file are faulty things do not work properly.
Go to C:\ right click properties / Tools / error check new box popsup
tick little box to fix errors and reboot
On reboot windows will check disk for errors and fix them
If this does not help please email me at [email protected]
Give a details description of what happens
SOURCE: having problems upgrading my laptop hard drive !!!
From what I gather basically you want to copy everything off of your 40GB and put it on the new 320GB and the install correct? Why don't you do a backup (Start>All programs>System Tools>Backup to the external 500GB drive. Install the new 320GB drive and then load the operating system from your operating system disc, then restore the data from the 500GB you backed up, or am I missing something.I know it is not as convenient as cloning but sounds like you may need to do it the old fashion way..there is no good reason that the cloning software would quit reading your disc unless it's some kind of "only get one chance and throw away software".
SOURCE: HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
Maybe due to some virus/malware running in the background. Also, can u let us know the OS/ antivirus software u are using
