It is a Duraband 13"
Do you mean the gray CRT Durabrand from 2004? I had one of those exact ones myself recently with the remote and everything.
You need a remote control to go back to the regular channels if you're in Game or Video mode (like watching your DVD player); those inputs are entirely separate from the channels to the point that you can't use the channel left/right buttons to get out of there. In fact, before I got my remote, I couldn't even get INTO Game / Video mode; I had to use an RF modulator on channel 3. For the Durabrand 13", the remote unlocks much more out of the TV.
SOURCE: Can't watch dvds with my dvd player
Try two different things 1) on some of these tv's you could try pressing 00 to see if it will put you in input mode or 2) with your remote you should be able to push the input or tv/video to go to the input selection . In both of the above make sure you push the tv button first then step 1 or 2 . Good luck
SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
SOURCE: Cannot get dvd to play on tv, no picture, try different channels, etc.,
on you tv must be a button "video/tv",you have to push this many times to find front, back or video1 or video2 (depent were you plug the dvd)and there is were supost to work. no on channel 3 or 4
SOURCE: hooking up a magnavox MWD7006 DVD player to a APEX TV
What channel should the dvd be on I have a magnavox dvd player and its all set up but can't get anything on
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
