Do you have a model # of your thermostat? Most of the thermostats come off their sub base by pulling the bottom corners out and then the tops have hooks that you need to lift the body of the thermostat up. So re-installing would be to hold the bottom off the thermostat out more than the top until the top engages with the hooks, then the bottom left and right corners snap in
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
SOURCE: Faceplate DEH-P5500MP
dude im real good at this stuff and if u dropped it once ur lucky it still worked but if it dont work now ur definitely going to need a new one...
SOURCE: Bought Dolce & Gabana gold faceplate, took apart, now cant get back together
you can send it to
http://horizonwirelessonline.com
we are cellphone repair specialists - cost is about $40 + shipping - and we can even give you the official D&G firmware too.
SOURCE: batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
