SOURCE: Kenmore electric dryer model 11060901990 wont start
I would recommend you begin by checking the THERMAL FUSE. The fuse is located on the air blower assembly and is a small plastic looking component with two wires attached. Make sure you UNPLUG the dryer before servicing and make sure you take any resistance readings with the component removed from the circuit. You can isolate it by simply unplugging the wires to it. A good reading will be something close to zero ohms.
The following link can give you some added advice on how to troubleshoot a dryer:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
If you do find the thermal fuse blown, it generally blows for a reason. This is usally attributed to something coming in contact with the fuse wires (like loose change from your pockets), or a dryer that has an obstructed exhaust vent. Inspect the interior cabinet and air blower fan for accumulations of dirt or lint, followed by an inspection of the dryer vent from where it leaves the back of the dryer, to where it exits your home. If the dryer exhaust vent is kinked or clogged, the dryer heating circuits will overheat to the point of failure. Failure to provide good air flow for the dryer will results in repeated component failures and can become a fire hazard.
If you have questions, please post back with your MODEL NUMBER (located on a nameplate around the door opening on Kenmore) and let me know. I hope you find this information helpful.
Testimonial: "Thanks!! I had to borrow a multimeter from my father-in-law. I tested the Thermal fuse, and it is bad, so I've ordered a new one with a thermostat. Thanks alot!"
SOURCE: crosley model ced5563rq, checked continuty
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
SOURCE: Whirlpool Duet Dryer - Working but no heat
I would check the heating element for continuity around 1200 ohms but if its closed and gives u a reading u should still be ok. as for ur thermostats the thermal cut off 0 ohms is ok as long as it does not read infinity or open circuit? CHECK THE CYCLING AND THE HI LIMIT thermostats also. Another thing to consider is , is the machine getting a full 220 at the terminal may need to check for votage from the outlet and to the machine. If u get say only 110 you will have enough to run the machine but not enough to run the heater which uses a full 220 volts. earlier u said something bout ur heating testing ok ? you did get an ohm reading?
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
