SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
SOURCE: Jenn-Air JGD8130 Gas Cooktop will not ignite
I just ordered one of these---sounds like people are not happy with this model---please get me more info
SOURCE: Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
SOURCE: I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
SOURCE: Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
