First remove the items from the freeze and place them in a cold box with insulation. Items should last for a day in the cooler. Try to move the freezer away from any wall. Unplug from power source. (place rags/towels/ etc. around the freezer.) If you have a room heater, let it face the freezer from a about 4-5 feet. Allow the area to drip onto towels (replace from time to time) and when it is dry to the touch, clean up the area, including inside the freezer and reset to the normal place etc. Turn the freezer on and let it get cold before you replace the frozen goods.
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
SOURCE: Ice build-up in lower freezer. We replaces the
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check , defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control. Part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MSD2756GEW&productCategoryId=0165000&brandId=3048&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00002&componentDescription=CONTROLS&documentId=M0404275&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: Amana ABB2224DEW bottom freezer defrost problem
You have a defrost problem. You will need to replace your defrost system. Before you put the parts on, you need to completely thaw out your unit. You can do this by leaving it open all day or night or by placing a fan close to it with the door open. We have parts, so please give us a call and we'll be sure to ge the right parts out to you right away. We look forward to hearing back from you.
SOURCE: Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
SOURCE: LG GR-349R bottom mount freezer gets heavy ice
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
