SOURCE: Motorola talkabout 200
Here is a link to the TA280 manual, which is similar to the TA200, http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Funny thing, I haven't found the TA200 manual in English. Here it is in Czech: http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf If you do a google search, you can find the page and have it translated. I'll keep looking, and if I find it in English, I'll repost.
SOURCE: my motorola talkabout(1998)will not connect to
Check that both the channel and subchannel match between the radios. depending on your specific model, the channel should be between 1 - 14 , and the subchannel should be between 1 - 38. If this does not work I will need the specific model number to assist further.
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
SOURCE: motorola talkabout sx900 will not communicate
Here is a link to the user guide. http://www.banoggle.com/Products/Motorola/manuals/SX900-manual.pdf Page two will be where you will find most of the instructions. Check your frequency, code and Qt filter. Make certain they match one another identically. If you continue to have difficulties, set the code and Qt filter to zero (or off), as well as the weather alert. Then try the units again. Hope this solves your problem.
Best regards.
SOURCE: Antenna for a Motorola Talkabout 250
Get a plastic tube (3/8 PVC will work) and use it as a mould. Pump it full of black RTV silicone. Fixed!
