Computers & Internet Logo
A
Alicia Lee Posted on Dec 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F engine menu keeps popping up on screen, all by itself
Amy Jaction
Level 2:
Sergeant:
  • Computers & ... Expert 133 Answers
  • Posted on Dec 26, 2017
Amy Jaction
Level 2:
Sergeant:
Answers
133
Questions
0
Helped
52934
Points
538
The HP device users looking for nonstop computer, laptop, printer, scanner, tablet, omen, envy, elitebook, probbok, mini, spectre, pavilion, laserjet printer helpline number they can dial the HP Toll Free Number which is introduced by the computer experts to assist their customers. Here the support is offered for the entire HP devices like laptop, computer, printer and tablets etc. This number is open 24 hours and the HP users of US and Canada can reach hptechsupportphonenumber.com to world class techies who fix the HP problems immediately.
If you are also willing for HP computer, printer, laptop, scanner, tablet, envy, chrome book, notebook, omen, elitebook, probook, zbook, mini, laserjet printer, inkjet etc. dial our HP technical support toll free number and sit back and the technicians involved with us will look into your concern and fix them accurately with 100% customer satisfaction and reliability.
hp toll free number, hp printer toll free number, hp laptop toll free number, hp computer toll free number, hp technical support toll free number, hp toll free phone number, hp customer service toll free number, hp customer support toll free number
Get in touch
Website: http://www.hptechsupportphonenumber.com/contact-us/
Toll-free: 1-888-687-4491
Working Hours: 24*7
Address: 21999 Hacienda Boulevard, California City, CA 93505 (USA)
5 Related Answers
Anonymous
  • 1030 Answers
  • Posted on Jan 04, 2008
SOURCE: tv problem
i have encounterd this problem a few times in the shop.. i resolved the issue by replaceing the front control panel pcb. i had one instance of a bad ir sensor causing the problem
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 19, 2008
SOURCE: Audio Menu keeps popping up
There are probably some failing components in the uPC control area, or with the keypad board on the TV sets front panel. It is also possible that there is a problem with the filtering of the distributed power through the circuit boards of the set, and there is some noise causing a false trigger of the function.
This type of fault can take some time for the tech to figure out, unless it is a published common fault with the particular model of set where they give a list of parts to change.
Jerry G.
Anonymous
  • 334 Answers
  • Posted on Oct 07, 2008
SOURCE: RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Anonymous
  • Posted on Mar 05, 2009
SOURCE: Menu Screen keeps popping up
WHAT BRAND AND MODEL NUMBER?
Anonymous
  • 63 Answers
  • Posted on Dec 16, 2009
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
My hisense tv keeps popping up the menu constantly
Probably a stuck button, either the menu button on the set itself is stuck or a menu button on a remote is active. Press the menu button on the set itself and see if that "un-sticks" the button, if it was indeed stuck. If the menu keeps popping up, take the remotes from the room and go back in without the remotes and see if the menu is popping up. Try the menu button again on the TV itself to see if that changes things. If the problem was a remote, perhaps it was laying wrong and depressing a button. Or, a button on it may have indeed been stuck. Bring the remotes back in and see if the menu starts popping up.
3helpful
My menu screen keeps popping up and wont go away
Unplug,replug about hour later,let see if it reset itself,see if it go away.Not the manual controllers board is dead,the board in the right of the tv.
1helpful
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
2answers
2helpful
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
3helpful
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
1helpful
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
RCA projection TV
Grand Canyon Tech
Grand Canyon Tech
