Video Cameras Logo
Gayle Kase Posted on Dec 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. My toppy has decided to play up. I can record fine but on playback, have black screen with message "service is not running or scrambled". Audio is fine though. Any ideas? Thanks, Gayle
Tony Parsons
Level 3:
  • Video Cameras Master 6,405 Answers
  • Posted on Dec 14, 2017
Tony Parsons
Level 3:
Answers
6405
Questions
Helped
1652345
Points
20272
What, exactly, is a 'toppy' ? If you can provide the actual make and model of the camcorder we will do out best to suggest a solution
5 Related Answers
A
Anonymous
  • Posted on Oct 23, 2007
SOURCE: Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Anonymous
  • 4402 Answers
  • Posted on Feb 12, 2008
SOURCE: Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Anonymous
  • Posted on May 27, 2008
SOURCE: WinFast PVR2000 - recorded video has no sound
I have installed the WinFast K8M890M2MA motherboard, too, but it doesnt show my hard drive on the 3rd IDE channel (S-ATA).
What can I do ?
Anonymous
  • Posted on Feb 11, 2009
SOURCE: BLACK SCREEN WHEN RECORDING
SORRY FOR DELAY RE YOUR PROBLEM
WOULD THE CAMERA HAVE BEEN SET AT MANUAL EXPOSURE WITH THE EXPOSURE SET WRONG
TRY!!
ROBERT
Anonymous
  • Posted on Mar 13, 2009
SOURCE: No playback pics. Blue screen.Can't record.Used x2 since service.
I just made contact with a service tech who seems very competent and who won me over. Have problem with video and audio dropout similiar to dirty heads on a 10 year old DCR-VX2000 but which is a larger problem attributed to worn parts which will need replacement. Do not know how old your unit is, but will share name of person/company if you wish. Only thing that worries me is if you by chance had had yours repaired by them!!! They are a Southern California company.
It appears as though the camera is not "reading" the tape. Though the tape is clearly playing (in the mechanical sense) during playback, the screen remains blue. The same with recording - The...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
2helpful
"unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
32helpful
3answers
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 • Dishwashers
3answers
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
2answers
Video screen is scrambled
bad tapes ive seen it before ..buy a different brand brandnew ones and give it another go.
thats why other tapes are working.
1helpful
4answers
1helpful
2answers
Black screen when recording but records audio.
This model Sony has a known defect in the CCD image sensor which will cause the camcorder to record a black picture or smeared picture. When played back, the sound will be fine but the picture will be black or smeared. Your older tpes you made before will be just fine when played. Sony is fixing this for free, postage paid. Go to their site, go to the support area and put in this model and you should be able to find the notice for this problem. They will send you a paid UPS shipping label to print out. You'll have your camcorder back working in about 2 weeks! :) Mike63
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
