Hi Cjjalbert.
this is all i could find out.
How to change date and time on fire stick?
To change the time zone:
Change the Date and Time
or try this link.
how to the correct time on firestick Google Search
SOURCE: what do i do
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
Manual can be found in PDF form from RCA here: http://support.rcaaudiovideo.com/Downloads.ashx?prodid=56&mediaid=620&force=true&file=products/RP5430/media/RP5430_UMEN.pdf
SOURCE: TV Guide onscreen is the wrong time
I've had this problem before, and always fixed it by going through setup again, setting the zip code to another zipcode nearby, and turning it off overnight. By the next morning the time has fixed itself. This is the only thing that has worked for me consistently.
SOURCE: on time atomic watch wrong time zone
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
SOURCE: ive been asked for my
You zip postal code is correct. Probably the survey you are answering is for US citizens or some other Countries available only.
Yes indeed they have a drop down list box of countries that includes Philippines but they also probably don't give services here on the Philippines.
Hope this helps, thank you.
-Cebu-
