SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
SOURCE: 2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
SOURCE: We have a Tefal Express steam generator Iron model
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
SOURCE: Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
