20 Most Recent Tefal Aquaspeed 155 Iron with Auto Shut-off Questions & Answers
Majority of the iron don't have fuse, you should check the plug and cord. Often it is become open meaning no continuity circuit, no heating. To be able to check it unplug, you should use a analog tester. Also check thermostat dial control, when it is not in right adjustment it is also cause a no heating symptom.
Good luck.
Tefal Aquaspeed... | Answered on Jul 17, 2011
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Tefal Aquaspeed... | Answered on Apr 02, 2011
if u have a bando then u sake it
Tefal Aquaspeed... | Answered on Feb 26, 2011
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Tefal Aquaspeed... | Answered on Jul 15, 2010
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Tefal Aquaspeed... | Answered on Apr 22, 2009
try to reduse the temperature setting first, if it still does the same then the thermal switch mechanism is not cutting off the switch at proper temperature
need to replace the thermal switch mechanism
Tefal Irons | Answered on Jun 19, 2019
USE BRAIN FIGURE WHAT TURNS IT ON .
Tefal Irons | Answered on Mar 02, 2019
Tefal Aquaspeed 155 Iron with Auto Shut-off Logo
19 questions posted
Top Tefal Irons Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Raymond Richards
Raymond Richards
Are you a Tefal Iron Expert? Answer questions, earn points and help others
View Most Popular
Tefal Irons
  • Tefal Irons
Most Popular Question
our tefal aquaspeed110 iron will not
  • Irons
