Question about Tefal Pro Express GV 8120 Iron
Tefal steam generator
Continuous steam
    Genius:
  • 1,554 Answers
The steam only comes out when you press the steam button In depth guide to the Tefal GV8460 Steam Iron with turbo boost...
Posted on Jul 25, 2014
5 Suggested Answers
Anonymous
SOURCE: Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Posted on Nov 13, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: We have a Tefal Express steam generator Iron model
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
Anonymous
SOURCE: Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Posted on Sep 20, 2008
Anonymous
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
My tefal steam generator is sporting steam without the button being pressed I have removed the lime scale tray and refilled but it is doing the same I'm worried II may be electrocuted
You can't be electrocuted. They are double insulated. you can descale it like you do a laundry iron.
Cleaning a Laundry Iron Get some CLR descaler and mix it to the directions. Turn the iron on and set it to steam. Turn the iron off and put the CLR into it. When it has cooled a little, sit it faceplate down in an oven proof dish. Leave it over night. The CLR will drip through and sit in the dish cleaning the inside, and the topside of the soleplate. The next day, fill with water and shake upside down to empty any remaining CLR and scale through the fill hole. Keep filling and shaking to empty until the water comes clean.
If you don't want to use CLR, you can use white vinegar undiluted.
Cleaning Laundry Iron
tefal steam generator Google Search
tefal steam generator descaling Google Search
Aug 30, 2018 | Tefal Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
cost £20.99
Nov 01, 2009 | Tefal Irons
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Tefal Pro Express GV 8120 Iron Logo
1,065 people viewed this question
Top Tefal Irons Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Raymond Richards
Raymond Richards
Are you a Tefal Iron Expert? Answer questions, earn points and help others
