When I turn on tv you can here the sound but only a white screen
SOURCE: polaroid flm 323b no power
FLM-323B same problem, black screen. Checked out the power board and there is no 24v on it. Took the board out, let it cool off, put it back in. Got my TV back for a while, checked for 24v and it is there. Worked for a few weeks, now it's out again. Known issue with Polaroid, and if it's out of warranty, might as well throw it away because they WILL NOT help you. Personally this was my first and LAST POLAROID TV ever, TOTAL JUNK.
SOURCE: I have a Polaroid tv 32
It is a long an tedious process, but I got the correct code, and my TV works fine. The following are the codes for Polaroids. Try them one by one, and you should find one that works
10765,10865,11262,11276,11314,11316,
11326,11327,11328,11341,11498,11523,11991,11992
Robbin
SOURCE: My 19 inch Polaroid FLM-1911 900t shows a white screen
your t-con board has failed check shop jimmy/com see uf they have a replacement
polaroids are hard to find parts
SOURCE: Polaroid FLM-323B Will not turn on
Polaroid FLM-323b No power,No led light, checked the fused and the fuse is good?
Can't find any bad Caps? Well I spent some time, well alot of time trying to figure out what's wrong and finally did.
The problem is a diode on the power board location Z9 Part # ( P6KE350A )On some boards it's the diode and the capacitor right next to it part # ( R 331K 1KV )
If this works Please donate Paypal [email protected] anything helps Ive spent well over a weeks time and count less hours trying to figure out what was wrong.I have included some pics to try and help.
Thanks Z28r2fast4u
