It seams to be running dosnt cool or freeze
SOURCE: Freezer fan is not working
the fan may be jammed due to ice build up. in the first instance i would give the unit a full defrost for 48 hours then see if the fan starts after, if not the fan motor may be u/s.
SOURCE: LG DRYER MODLE DLE0332W
If it is running, chances are one of the thermostats are gone. You have two on the heater bank, a high level and a safety, have them both changed.
Sgt 48
SOURCE: Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
SOURCE: freezer not freezing, fridge is about 50 degrres in my lg side by
Check the relay on the compressor. But in order to due this right you are really going to need to have a company replace yor condensing coils and your drain pan. Check also the thermostats. Located under the dials to adjust your temperature settings. You can get some of the parts at repairclinic.com
SOURCE: freezer staying frozen fridge not cooling
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
https://helpdeskminority.com/?s=freezer
