First off try to pull the battery start computer without the battery if that does not work next try to enter safe mode windows 10 F10 Windows 7 F8 for safe mode. try booting it up to a post screen if that does not work you need the backup disk or the repair disk for that computer 1.follow boot instructions screen will pop up as a post screen select repair computer.if you cannot repair the computer as it says it failed you need to boot from the system disk try to upgrade the system with the disk so you wont loose data good luck please let me know if you need additional help. Best, Donald Deane MCSE,ASE,CPO
SOURCE: On boot up screen reads "Loading PBR 2...done"
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
SOURCE: hp g60-120us computer will not boot, passes
F12 to get boot menu then select CD. The CD drive should led up. If it doesn't read the CD clean the CD in straight motion, try another boot CD as well. If it won't read at all, then your CD drive may be defective and need replacement.
SOURCE: i can adjust screen brightness
Typically there are two ways: through the keyboard, usually a function button and brighter or darker button, and 2nd in the power settings. Lower screen brightness gives much longer battery life.
SOURCE: frequent blue screen error on
You need to remove the ram and clean it, possible check the proccessor condition(thurmal heat sink cream on it),clean the dust in laptop you will see differance.
SOURCE: HP probook 4420s stuck on mute
Locate your Fn key, and look for the speaker icon, mine is on the Ese button, yours maybe on one of the F buttons at top, once found. Press Fn key and hold now press the F key that is the speaker icon, sound shuld be restored.
