20 Most Recent HP Hewlett Packard 2000-410US 15.6" Notebook PC - Intel ... [A6Z99UAABA] Questions & Answers
How do I change my paassword
to BIOS admin or w10 login we can not see your screen ok/?
  1. lost it
  2. bought PC dead like this
  3. or out of the blue this happened and not before now.
if you did not loose it and only waHT TO CHANGE IT HP.COM READ YOU MANUAL THERE ,ON 2000-410US IT COVER ALL THAGT BUT NOT #2 OR #3
1/14/2022 9:39:25 PM • HP Hewlett... • Answered on Jan 14, 2022
Why does java stop working trying to download a movie on mp3 rocket on windows 10?
Possibly Rocket not compatible with newest version of Java. You might have to download an older version of Java. I could check out the Rocket requirements page to see what version of Java they recommend. If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
3/18/2016 10:34:16 PM • HP Hewlett... • Answered on Mar 18, 2016
How to move mouse pointer and click on laptop without a numeric kaypad
You cannot. Get a cordless mouse.
1/16/2016 3:15:05 AM • HP Hewlett... • Answered on Jan 16, 2016
On the 21 of Oct I purchased AVG and had it and now it's gone. How do I get it back?
You can download AVG antivirus again linked below. Locate your serial / key from the box or email and enter it to activate the premium features. If you run into trouble, contact AVG support (also linked below). Make sure that you're installing on the same computer / or that you are moving it to a new computer - most licenses provide for ONE serial / key per computer. You'll need to buy a key for each computer you want to install with premium features enabled. Good luck! http://www.avg.com/ww-en/homepage https://support.avg.com/choose_support?l=en_US
10/30/2015 12:24:47 AM • HP Hewlett... • Answered on Oct 30, 2015
0answers
2answers
Cursor is frozen
Try powering off your laptop by removing the battery and power cable off. Now while the power cable and battery are off the laptop, press and hold the power button for 60 seconds (You are doing a power drain by this) Put the battery back on and boot up the laptop - See if that helps. Let me know here. Thanks. Peace
4/21/2015 2:22:50 AM • HP Hewlett... • Answered on Apr 21, 2015
How do i fix black screen on a HP 2000 notebook PC running Windows 8 ?
graphics failure is the common cause,is warranty repair an option?
8/31/2014 5:36:25 AM • HP Hewlett... • Answered on Aug 31, 2014
How to delete frequent sites on explorer bar not favorites, my bad .
I use CCleaner for that. So now and then I run this program to cleanup my computer from history(s) cookies and lots of other stuff.
6/21/2014 4:50:11 PM • HP Hewlett... • Answered on Jun 21, 2014
Hard disk 1 (3f1) error
Hp says it is a potential problem with your external hard drive.Download Hard Disc Sentinel,the free version will give you enough info on the HDD status to determine if it has an issue.The other alternative would be to unplug the drive before you bootup to avoid the message - plug it back in when Windows has loaded and check the drive for errors or problems by clicking on: My Computer - right click E drive or whatever letter the drive has - click on Properties at the bottom of the options panel - click on Tools which opens check disk options.Good Luck
3/17/2014 6:22:01 AM • HP Hewlett... • Answered on Mar 17, 2014
Wifi adapter dont work but i can connect with my phone
Please check the WiFi connection: Control Panel, Network and Internet, Network Connections. Is there any WiFi item in this screen? Please post it in here, so I and other helper can help you if you still need help.
3/3/2014 3:45:17 AM • HP Hewlett... • Answered on Mar 03, 2014
2answers
Hp Photosmart C5180, What is the Special Key Combo
redux 2: unified)No history at all, like how can 2006 printer just fail 2022. impossible. there is story but none told (bought it used 7 years ago)not told how LCD fails, we can not see if failand does, and not told exactly what it did.we learn later it can NOT SAVE ANY SETTINGsVirus = settings dead is what we learned.LCD settings will not save !BATTERY IS DEAD, NOT ONE EVER LASTED 16 YEARS.FACTS.:1: BATTERY IS DEAD.2: RESET MAGIC DOES NOT FIX BAD BATTERY (SURE)3: MAGIC, PRINT TEST PAGE FAILS PROVING PRINTER IS BAD, AND NOT SOFTWARE EVER FIXED A DEAD PRINTER.dead is dead, and hint #1 is LCD + setting + language will not SAVE.Hp Photosmart C5180, What is the Special Key Combo http://h10032.www1.hp.com/ctg/Manual/c00737535.pdfNOW WE know what infected means.?it means he LCD settings are dead. dead as a door nail , save settings fails hard.yes the manual showsspecial key press for master restand more key pair press for print test page that is dead.the test page works with NO PC or USB any data cables at all. so printer is dead onlyand not software.ANd test page is dead,due to all settings lostdue to , battery dead. all settings lostit can not even understand what language to print in as that is lost too.solvedrefr.bad coin cell. (how to get there video)https://youtu.be/JNiBZ0lHn7g?list=PLCCcBpjpBYbhYdsOmNYa9C0X7LXoeLGCw&t=209jpg of it 10x more clearhttps://i.ebayimg.com/images/i/331333687624-0-1/s-l1000.jpgone of the last C5180 running on earth.unless full service done but there are no new parts sold for it, so magic like that can not happen.yes paper, ink, and coin, yes yes yeshere is the official HP parts surfer list.https://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=Q8220Ano electronics sold and all else out of stockuse your product number to get correct listah a wireless kit is there and upgrade.same page Dec-31-2013 (a 7 year support life)all support ended 9 years agoonly used parts on Ebay,
1/24/2022 4:35:03 PM • HP Computers &... • Answered on Jan 24, 2022
2answers
Where is the microphone jack located on a HP w2338h desktop? Every time I plug the microphone into the jack on the monitor the speakers stop working. I've made sure they are both enabled.
As you have found the connection on the monitor itself, I'm unceratin why you ask where it is. It the HP documentation below does not help, perhaps one of the following videos will offer the solution you seek: https://support.hp.com/us-en/document/c01643091 https://www.youtube.com/watch?v=QUybgDbb6p8 https://www.youtube.com/watch?v=QUybgDbb6p8 https://www.youtube.com/watch?v=hL2L8ZvPeeU
1/19/2022 10:53:48 PM • HP Computers &... • Answered on Jan 19, 2022
Hp 255 not booting flashes caps and wifi
the HP.com manual on your PC tells what those POST errors are caps flash, for sure, and beeps too. Hp 255- dash what. a NOTE BOOK PC IT IS. no told full model name so manuals are impossible to tell G1 to G8 dash? not told 8 generations RTM read the manual at HP.com sure I bet G1 is now gone sure but we can find them googling with real model numbers not told sure can, do so. btw POST errors are hardware failures, mostly we run full diagnostics next from HP.com and it finds the cause. top fails CMOS RTC BATTERY DEAD. HDD DEAD. OS INFECTED. BOOT FAILS A WRECK , CAUSED BY HDD BAD MOST TIMES. LEARN TO FIND THE POST ERROR CODE FIRST the blink codes on some are tricky. dual codes 2,3 2 short 3 long yes tricky learn that in the manual too many codes caused the,to do that, odd flashing.
1/19/2022 3:59:25 PM • HP Computers &... • Answered on Jan 19, 2022
How do i download whatsapp?
google finds it first hit ever GOOGLE?
1/19/2022 3:39:21 PM • HP Computers &... • Answered on Jan 19, 2022
HP Compaq 6000pro powers up then shuts off seconds later help as was working few days ago shuts off and flash's and beeps
old old COMPAQ (now HP 2002 forward in time) Q43 chip set. 6000 MT or DT or SFF size not told and are not the same. last one was 2009 called form factor,post a photo and I tell you easy came with virus magnet new XP. or VISTA. (only) there are 20 reasons to shut off (in time, ? not told you how long from dead code. 1second 1min 10m, 1hr> what? time matter if PC overheat it may do that in 1 min flat or not at all on desktop OS.but my only overheat gaming (AAA top games) the flash are flash codes as are beep codes the manual on your pc covers PoST error codes all. and means hardware failure (99% or more) we run tests and diagnostics on PC dead. we know 2 things this old coin cell cmos battery is dead. and hDD bad this old we run SMART test on all old HDD . one beep codes is OS is dead boot fails bad ,missing or corrupte HDD is top cause of that PC can overheat, so we run CPU/GPU Temperature app to see if pC is 50C or 90, , 90c is auto shut down temp ever clean the all lint out of the PC after 7 years ran. oops fail it will. no all other causes IF the PSU sees one of 20 devices in the PC Short out and this is called PSU power rail overload. and ATX spec is 1 second or less Look Ma' no fire. (grin) to find lover loads we do the strip down tests. after new coin and full hdd sets pass. https://www.pcdied.com/PSU/strip-down-testing101.html#min_sys there you go how diagnose old PCs your POST errors are all here. the error manual (LoL) http://h10032.www1.hp.com/ctg/Manual/c01870980.pdf
1/19/2022 3:38:37 PM • HP Computers &... • Answered on Jan 19, 2022
How to hook up dis on your hp laptop hstnn.pro7
what does DIS mean? the PC Pavilion G6 remote control? hp.com go there and read the manual on your PC. it is there.
1/19/2022 3:04:49 PM • HP Computers &... • Answered on Jan 19, 2022
2answers
My Elite Book 8530p is not booting. My drive does not work. Please tell me the fix.
Although the HP support site says no drivers are available for this model, it does suggest you try to manually reset the computer. The following page may offer a method. https://www.youtube.com/watch?v=IQ7ehpMwCZo Below might also be of assistance. https://support.hp.com/us-en/help/diagnostics?category=computing
1/19/2022 1:49:41 PM • HP Computers &... • Answered on Jan 19, 2022
HP Hewlett Packard 2000-410US 15.6" Notebook PC - Intel ... [A6Z99UAABA] Logo
25 questions posted
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
21 oct purchased avg now s gone get
  • Computers & Internet
