SOURCE: cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
SOURCE: coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
SOURCE: Coffee Maker Not Working
hi i hope i can help you? may i please ask does the water heat? if not if you have a multimeter open it up and check the hot plate. and the connections even if the light is on there the other side of the switch. you can get these meters from maplin electronics for about £8 £9 very cheap but will last for many years.
SOURCE: I'm looking for a manual
found it nowhere just the one here see if this can help.
http://safemanuals.com/manufacturer/RUSSELL%20HOBBS.php
SOURCE: coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
