SOURCE: Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
SOURCE: my new front loading washer
Most Maytag front loading clothes washing machines made with a "door locking mechanism" to prevent opening door during a spin cycle. The "door locking mechanism" adjustable and often continued slamming or hard closing of door causes misadjustment of "mechanism" preventing machine from sensing door "locked" and entering a spin cycle. Check alignment of latch mechanism. Machines also produced with a "creative fix" by either factory and/or service technicians using folded paper or cardboard behind latch mounting mechanism to align mechanism; over time paper or cardboard compresses chaning alignment. Check the mechanism alignment before checking electrical boards or switches on motor and belt drive..
SOURCE: red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
SOURCE: EVERSTAR COOLER HDBC36ID
Mine is 11 months old - pooling water on right (which is theside i keep colder for beer/soda/water), also my glass door on right has water between panes, I just called franklin (everstar) and they say a service guy will call in 5 days... I hope.
Did you get help and are you 'happy' with the service done?
SOURCE: 32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
