SOURCE: rca 2625 cd shelf system
1. Check all cable connections to make sure they're secure. 2. Replace the cable connecting the unit to your speakers. 3. Make sure that the unit is not on MUTE mode. if nothing works, you can try to replace the speakers, and hope for good :)
SOURCE: Finding repair locations for Briggs & Stratton Pressure washers
Empty the gas tank and, if you dare to try, the carb bowl too. If you don't dare don't worry about it. Refill with fresh gas, start it up and let it run. If it doesn;t run too good trying cleaning or changing the plug.
SOURCE: CD unit unit displays ''No Disc'' when there is a disc in slot 1
What does it do if you put 3 discs in and select each one? You don't say what it does with the other two trays. It would help to know that they work. If not, you have a bigger issue. Let me know.
'no rdy' meens not ready so you disc tray is stuk take it a part and dose it make a noise az if the cogz are sliping if so the lil band in side you disc tray has broke
